PWM Y-Splitter only runs one fan?
3 May 2004
Hi,
Im trying to run 2 fans on my radiator but I can only get one fan working.
Using a Y-splitter cable, the fan that is connected to the full 4 pin plug works fine. The one with 3 pins wont work at all.
Any idea why this is or just a faulty y splitter?
it will more than likely be a faulty cable the missing pin on your spliiter is the one that reports the fan speed back to the mobo or fan controller. you've tried swapping the fans over to make sure the same thing happens
