Pyronix question
17 Dec 2015
I've just fitted a pyronix enforcer and it's working great so far I've just got a few questions ... it's a wireless system including the wireless bell box, does the bell box have a strobe light as I have not seen anything lit up at night is this correct ? Also the bell box chirps every time the alarm sets again is this correct or is something wrong ?
Last one as it's the first alarm we've had we do keep forgetting to turn it off in a morning and as soon as a pir sensor spots us it activates the alarm straight away is there a way to give us say 10-20seconds countdown to turn the alarm off before it activates as I can't see anything in the manual cheers
My bell box is hard wired and lights up but the rest of the system is wireless. You might find as it is wireless, to conserve battery power it won't be lit.
My control panel makes a noise when setting but not the external bell box.
You need to set up the areas so that some sensors give you time to disable the alarm, in the same way the front door contact should be. To be honest you get in a routine and stops my children sneaking downstairs and trying to disable the alarm!
