Python help - Bubblecomparison
1 Mar 2003
Cotham, Bristol
Hi folks having a slight brain fart here :(
Say I have a list of the following elements
['','','a','b','c']
Now my aim is to compare two adjacent elements, if the first one is blank and the next in the list isn't then swap the elements, otherwise do nothing. So at the end of the processing the list should look like
['a','b','c','','']
I'm using a bubble sort type comparison thing, but i'm not entirely sure if this is correct. Can a kind person have a look at the following for me and say if i'm getting it right?
Code:
import sys
import string
import techrtime
address_fields = 0
def format_address:
    full_address = techvars.full_address
    address_list = full_address.split()
    address_fields = len(address_list)
    for current in range(len(address_list)):
        for record in range(len(address_list)):
            if ((address_list[current] == "")&&(address_list[record] == "")):
            else:
                address_list[current] = address_list[record]
                address_list[record] = ""
                break
Updated code, still having a bit of trouble with it :(
Code:
# Common code to despace address lines
# Author : Paul Statham
# Date : 14/07/2006
# Version: 1.0
import sys
import string
import techrtime
def format_address:
    # Get tab delimited address string from Openprint
    # Split the address into a list
    # Loop through the list swapping list items where necessary
            else:
                if address_list[current] != "":
                break
    # Set all blank items in the list to a tab delimiter
    for current in address_list:
        if current  == "":
            current == "\t"
    # Reset the full address
    full_address = ""
    # Loop through the list appending to the full_address
    # string as it continues
        full_address += current
    # Finally set the Openprint address string to be
    # correctly formatted
    techvars.full_address = full_address
