Python log filtering help
3 Feb 2010
Behind you
So i have 7 different files:
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
and i am trying to filter the data from the logs in to a CSV file, i am having no problem doing it 1 file at a time, but is there any way of running it across multiple files in one go, all collating into one CSV file?
Any help would be greatly appreciated
Code:
import apache_log_parser
from csv import DictWriter
parser = apache_log_parser.make_parser('%h %l %u %t "%r" %>s "%{User-agent}i"')
with open('cleaned_log_1.csv', 'w') as out_f:
    writer = DictWriter(out_f,
                        fieldnames=['remote_host',
                                    'time_received_isoformat',
                                    'request_method',
                                    'request_url_path',
                                    'request_url_query',
                                    'status',
                                    'request_header_user_agent'],
                        extrasaction='ignore')
    writer.writeheader()
    ip_map = {}
    with open('u_ex150601.log') as in_f:
        for line in in_f:
            line = parser(line)
            #start of IP address anonymization
            ip_addr = line['remote_host']
            if ip_addr not in ip_map:
                ip_map[ip_addr] = str(len(ip_map) + 1)
            line['remote_host'] = ip_map[ip_addr]
            #end of IP address  anonymization
            writer.writerow(line)
Nevermind - sorted it, not the most "majestic" code.. but it works..
added a bot filter too
Code:
import user_agents
with open('cleaned_log.csv', 'w') as c:
   writer = DictWriter(c,
                                    'request_method',
                                    'request_url_path',
    ip_map = {}
    with open('u_ex150601.log') as a1:
        for line in a1:
            line = parser(line)
            ua = user_agents.parse(line['request_header_user_agent'])
            if not ua.is_bot:
    with open('u_ex150602.log') as a2:
        for line in a2:
            line = parser(line)
            if not ua.is_bot:
    with open('u_ex150603.log') as a3:
        for line in a3:
            line = parser(line)
            if not ua.is_bot:
    with open('u_ex150604.log') as a4:
        for line in a4:
            line = parser(line)
            if not ua.is_bot:
    with open('u_ex150605.log') as a5:
        for line in a5:
            line = parser(line)
            if not ua.is_bot:
    with open('u_ex150606.log') as a6:
        for line in a6:
            line = parser(line)
            if not ua.is_bot:
    with open('u_ex150607.log') as a7:
        for line in a7:
            line = parser(line)
            if not ua.is_bot:
Code:
import user_agents
                                    'request_method',
                                    'request_url_path',
    ip_map = {}
        for line in a1:
            line = parser(line)
            if not ua.is_bot:
        for line in a2:
            line = parser(line)
            if not ua.is_bot:
        for line in a3:
            line = parser(line)
            if not ua.is_bot:
        for line in a4:
            line = parser(line)
            if not ua.is_bot:
        for line in a5:
            line = parser(line)
            if not ua.is_bot:
        for line in a6:
            line = parser(line)
            if not ua.is_bot:
        for line in a7:
            line = parser(line)
            if not ua.is_bot:
Don't do that. Create a list that contains all the filenames and then loop round the list and do what you need to do for each.
holy copy & paste, batman! :eek:
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
u_ex150601.log
Good attention to detail! ;) I wonder where your code gets the copy/paste from! :p
Is this a 1 time job or is this going to be something you have to do every X hours/day/weeks?
Are all the logs sitting in the same folder? Are they removed at any point?
If it's a one time thing, what you have isn't in keeping with python.
1) Create a list that includes the log files
2) Create a function with the open/write log code in it
3) Create a loop that calls the list above and the function
The added benefit of this is you're only creating 3 sections of code (list, function, loop) as opposed to 8+ in your current example. It's also expandable, introducing a new log is a simple case of just adding it the list.
Other options to advance it, have a log folder, with a completed folder inside it. your code scans the folder every X minutes, if there is a new file in there it opens it, reads it, copies into csv and then moves the file into the completed folder for you. Throw in a backup folder if you'd like the original file backed up before running the code. Lastly, what happens if it errors? move the file into a FAILED folder and notify you of the issue, but you'd have to generate some failure processes.
I'd also have the code copy into the CSV file the log name that it came from so if you need to you can check it manually if something doesn't look right.
