Hey guys.
I'm looking at adding my 1080Ti to my custom loop at some point. However i aiming this question specifically at people who have overclocked their 1080Ti and most likley have it under water or a AIO solution.
When up around the 2Ghz + mark do you often find it still throttles down? Iv'e seen a lot of people on the net even under water say it still throttles and reason being is it's still hitting that power limit even at 120%. This seems to be knocking the frequency down to 1950~Mhz for some people
Now if that's the case i'm seriously going to consider doing the shunt mod with some various precautions
Going to use clear nail varnish gloss stuff to put around the solder points and the area of the two shunts i will be shorting then using a glue gun to make sure the liquid metal does not go anywhere. This should provide added protection and if needs be very easily reversible. Iv'e seen lots of people just add Liquid metal and get a good 30% drop in the power limit which is more than enough.
I just don't want to go to this extreme if its only going to warrant a possible 50-70Mhz extra overclock stable.
If i do go down this route after serious consideration i will post my findings etc just incase anyone else is considering it. I guess AIB cards wont have this power limit problem though as they will have hardware level modifications to nVidias design that overcome this. However then there is the Voltage problem lol.
to remove gpu boost and then it will not throttle, i did this with my 980TI`s
