I just wondered if you run two consoles on one cpu, say one low priority one at 5% cpu usage or something in case the main console cant connect to server for whatever reason, then do the Folding stats say that you have 2 active cpus?
if it finished a WU and sent it then yes it would show as an extra active CPU
however if the main client failed then the backup would continue to only use 5% of the CPU
the solution is to set the main client as "low" priority and the backup client with deadlineless work at "idle" priority - you can also set the backup client to send and receive work in batches so it can queue up to 10 WUs in case you lose your connection
