Q micra very nifty matx case
They look promising, I like the layout. Like a cross between the Aria and the Sugo. The silver one looks the best IMO.
It's also nice to see some front intakes on a cube case for a change
Bad points:
AKASA sound proofing can be found inside the case
Qmicra is currently on sale as part of a small form factor system and in limited numbers as a promotion
Good points:
PC Design Lab also strives to give back to the community by donating a portion of their profits to local charities and by supporting the local economy.
:eek:
The case is also compatible with many aftermarket coolers, such as the Zalman CNPS950
:eek:
Many sections of the case are removed without difficulty, making for easy access.
ive been been looking at matx cases for my next upgrade, atm i got 3 shuttles but i like this case the most. just a shame its hard tog et hold, £200 or so to import
been looking for an matx case and so far this one seems to be the best ocuk please stock it :p
It doesn't look much different to a Q Pack
Its similar spec and size ( judging by the drive bays )
Seems a bit overpriced compared to Aspire and the Q pack comes with a better front IMHO. ( but I'm bias )
Looks nice in silver but i don't really like the chamfered edges and the bars that run along. Don't really see the point.
Only other issue for me is that although it does have front intakes they are tiny and don’t really see how a huge amount of air would be drawn in. Look as though they were intended for two 60mm fans or something.
Layout looks very good and hopefully will be something other manufacturers pick up on. The ability to fit proper coolers in is very nice.
I'm still waiting on the lian li V300 myself (Whenever it appears).
Sandmaster500
Sandmaster500
seen it listed on a US site $240 IIRC
Nope Evo's been available for ages , just gotta look for it :)
Apparantley Theres a sugo2 in devolopment, no idea when its gonna be available tho :(
