Q3 Arena steam
26 Nov 2008
Leeds
Got this in the quake sale a while back but i have just installed it, i am having major corruption issues on the menu making the game impossible to play. Did anybody else have this and is there a way to fix it?
You could try downloading and installing ioquake3 and then using the pak files from your steamapps folder with it.
Essentially Id released the source code for Quake 3 a while back, so ioquake3 is an open source project that takes the source code and modernises it a bit. Of course Id didn't open source the textures etc, so it will need the files from your Steam version to work.
[edit]
You can also change your graphics settings using the console, which may help with any graphical corruption in the menu system.
Bring up a console as you would in any other game (the key next to 1, usually ` on a UK keyboard)
type the following commands:
Code:
r_mode -1
r_customwidth yourdesiredresolutionwidth
r_customheight yourdesiredresolutionheight
vid_restart
There was a great guide on the steam forums which fixed the blurry menus as well as a few other issues. When/if they come back up, I'd start there.
Make sure your not forcing any of these cvars:
r_displayrefresh
r_depthbits
r_swapInterval
r_finish
If your just wanting to play quake 3, rather than a specific mod, etc. then head over to www.quakelive.com
I dread to think how this looks, as all I have left is fond memories from 1999 - 2003 between CTF/TDM and Q3F/2.
