9 Jan 2007
got mine and dropped in msi p7n diamond with 4gb ram,left evrything at stock including cpu cooler,just raised fsb from 1066 to 1333 and im getting 3 ghz with 32 degrees idle and 38 degrees under load in a coolermaster stacker with 7 x 120mm case fans,should i raise core voltage (1.23v currently? anyone? prime stable at 12 hrs
Thanks
Wessa1
No need to up the core voltage atm. You may get to 3.1ghz before you need to touch it.
Those temps are fine. I'd raise vcore to somewhere between 1.3v and 1.4v and try and find a nice high stable point. Make sure you keep an eye on the RAM speed :)
Thanks
Wessa1
dont increase volts at current speed, because it will only make things hotter..
try 1.3v at 3.6ghz seems yours can handle it just fine.. also use coretemp (if not using it already)
;):D
