q6600 advice
3 Mar 2009
Near Hastings
Iv got a Q6600 cpu and i need advice on cooling :p
i got Coolermaster HAF 932 Case and im thinking would Zalman CNPS9700-LED CPU Cooler (Socket 754/939/940/AM2/LGA775) be enough for non overclocked Q6600?
just wanna make sure so it wouldnt go boom in the end :D:D
It should be fine, there are better coolers, but it will depend on how high you intend to overclock and your budget.
Should be fine, also have a look at the Tuniq Tower and the Thermalright range which are I beleive equal or better.
