Q6600 and Abits OC Guru software
10 Aug 2005
Hi people
Ive been playing with abits overclocking software and must admit i like being able to overclock 'on the fly' as it were. But i have a few questions for other users.
1. The default setting is i assume for the stock chips speeds but what vcore are you guys using for stock on a GO processor?
2. When an overclock attempt goes wrong and the system hangs do you need to clear the cmos as this will mean filling in all your bios settings again,or do you just reboot and hope the software will sort out the problem?
3. Do you need to have 'load at startup' checked in the options for the software to properly recover from a bad OC attempt?
Regards
The default core value is known as the VID, the board will normally default to this if set to Auto. Use Coretemp if you want to know the value, each chip is different.
