Q6600 AND E5200 Power usage in real terms.
Caporegime
24 Dec 2005
Autonomy
Running stock in a HTPC what is the real world difference in Power usage between the two?
Big wayne?
How much money will I save?:cool:
How much do you pay per kWh?
How many hours a day will the PC be running?
What is the Idle and Load power wattage of the system as measured by a Watt-O-Meter thingie? :D
[edit] are you undervolting both chips?
If you we're running them on 100% load there would be about a 30W difference which is 720W Extra a Day.
About 5-6p difference a day dependant on how you a kw/h costs you and assuming it will be on full load which i doubt.
what would idle be?
cheers
You may also want to take into consideration the extra fan wattage to cool the Q6600 and the noise it will add.
I have the zalman 9500 running at 7v so its silent.
I'm just trying to ascertain if changing to a E5200 would be that much better for the environment and my electricity bill.
Well the wolfdales really don't use much power....here's my E7200 clocked to 3.8ghz 1.34V under 100% load (orthos stress cpu). Stays between 36-45ish Watts. Here's a screeny of the highest I've seen.
My Everest ultimate (lastest build) doesn't have the GPU A or CPU wattage ratings :( Any ideas?
My 3.33Ghz E5200 rig, 2x1Gb pc2 5300 Patriot Extreme, Gigabyte P35 DS3R, 3850 Pro 512mb, Creative Audigy 2ZS, Samsung sata DVDRW, Seagate 7200.10 sata 320Gb hdd, Zalman ZM-MFC2 multifuction controller, 4x 120mm fans, Akasa Neo Vortexx, 92mm fan on the cpu cooler, Enermax Pro82+ 385w psu pulls 80w at the wall idle and 205w when running Orthos and Fur at the same time. Running at stock speeds only knocks a couple of watts off.
Don't know if that's any help to you?
It will show if the hardware supports it. Some Asus boards have the EPU chip thingy which monitors current draw I believe....and 4870s show VRM current draw....as do GT200 cards
