I have a PC that runs mainly the following:
1. Win XP
2. Kaspersky Internet Security
3. Outlook 2003
4. SpamFighter
5. Some proprietary processes that number crunch stuff.
All run simultaneously, except for #5 that kicks in once every 10 minutes or so, for a couple of minutes.
If I go for a Q6600 processor, will 3 of the cores handle 1-4 and then when task #5 kicks in, then the final core handles it? I am trying to avoid the CPU hitting 100% and freezing up the system so other processes grind to a halt.
Can you allocate a program to a core so it has exclusive use of it?
If a program is not designed specifically for a multi-core machine, does that mean that when it runs, it can only use up the power of one processor?
Thanks,
Jon
1. Win XP
3. Outlook 2003
4. SpamFighter
Thanks,
Jon
