Permabanned
- 8 Feb 2004
Hi
I needed to put a fair few volts through my Q6600 to get it Prime stable at 3.4 GHz... However I noticed my tempeartures were still pretty low.
In the bios my Vcore is set to 1.525 and under full load my tempertaure hover around the 52 deg C mark.
When I load CPU-Z I notice that it reports a core voltage of 1.472 when idle and 1.44 volts under full load... Is this just a case of volt drop on my motherboard? My PSU is good (620W Corsair) so doubt if it is to blame.
FYI My motherbaord is a Gigabyte P35C DS3R. Is this volt drop a problem? If I want to try for a higher OC should a just set it higher in the bios but believe the value CPU-Z gives me?
(relative to stable load vcore of course )
