Hi there,
I have problems with my Q6600 and some strange voltage issues. ATM it's running at 3.2ghz (and has been for the last year or so).
If I set 1.465v in the BIOS I get 1.40v idle (CPUZ) and 1.304v under full load. I know that this is vdroop, but it seems excessive?
So what gives? Load line calibration on the vanilla P5K doesn't do anything, apparently (certainly doesn't in my case). Is it safe to have it at 1.4v idle - seems really high for 3.2ghz? Any other settings I should be looking at in the BIOS? NB, SB, etc. I've not touched.
Currently 3.2ghz is the max I can get out of it but I'd like to see 3.6 @ 400fsb. It's a G0 SLACR so it's supposed to be a good one, isn't it? Temps are around 60'c under full load, but that's ok, right?
Help! Any ideas?
Cheers
Help! Any ideas?
Cheers
