Doing fine with an AC7 at 3.6GHz here. Highest I get on a core is 65-66 under max load.
can you post your prime shot in the quadcore database
I have a big spreadsheet of Coolers vs Clocks nice to keep it updated and that would certainly be the highest clock on an AC7
if I could get it prime stable at 3.6gig around 1.4-1.45 as some are it would be around 57C under max load. (at 1.4 my idle temps are 25C
its a Q6600 on a P35 board I'm talking about.When i had the quad clocked to 3.4 i was using a voltage of 1.4125 for that speed under the acf7 the first time. Managed to get the volts down to 1.3750 for 3.4 under the TRUE at the next attempt, subsequently discovered that the chip would do 8 hours + using 1.4125v for my current clockspeed of 3.6ghz.I have a lapped ACF7 pro on my Q6600 and idle temps are around 30C and load around 65-66C under OCCT at 1.5v - unfortunatly my Q6600 seems to be a poor clocker anything above 3.4gig takes a hideous amount of voltage to keep it stableif I could get it prime stable at 3.6gig around 1.4-1.45 as some are it would be around 57C under max load. (at 1.4 my idle temps are 25C
EDIT: I'm not OCing the Q6600 on the board in my sigits a Q6600 on a P35 board I'm talking about.
EDIT2: bah getting annoyed with this chip does upto 3.5gig with 1.4vcore then needs 1.55+ to get 3.6 stable :S I should have just gone for an E8400 or 8500.
I'm using a Zalman CPS9500 on my Q6600, does anyone have any experience with this cooler?
Un overclocked, I'm idling at 17 degrees (according to the bios) but I'm sceptical of this figure?
Also, as a note, if anyone has the Asus P5E don't buy the Zalman as I had to cut the clamp down to size as the Mobo heatsinks got in the way...
