Hi currently running a Q6600 on a 680i lt @3.7 GHz.It`ll boot into Windows and run 3d mark any version you like at 4 gig but priming sends the temps 75+ with a crash about the same time.I`m currently using an EK Supreme block with a Thermochill PA 120.2 and Laing DDC1 T pump,anybody got any better block suggestions 'cause I'm sure the rad should handle a quad.I`m using MX 2 tim and the block`s been reseated several times (core voltage of 1.5 ish with a VDroop mod)
Cheers.
Cheers.
