I'm looking to build a new rig with An Antec 900 case, Asus P5K-E and either the artic cooling Freezer 7 or the Tuniq tower 120, will either of these coolers have any problems with my chosen mobo? I'm looking to get a 3.4Ghz OC if possible
To be honest I think you will struggle with anything over 3ghz with the Freezer 7. I have it installed and at 3ghz it's fine, but get's toasty at 3.2 and above.
and has good airflow. I wish I`d of got the Tuniq now
I was at 3.6GHz on the STOCK cooler without issue
Currently benching at 4GHz on phase change though![]()
Oh and probably RAM that doesn't like being above 860...Erm...
I'm at 3.4 GHz (430 X 8) with an arctic cooling freezer 7 pro on a Q6600 with max temps under load being 60 degrees (Prime95 small FTT torture test), all in an antec 900 case. That's also using the supplied thermal pad. Oh and an Asus P5E X38 mobo.
So it can be done![]()
otherwise thats a nice OC on airWhat are you using to calculate your temps?. If your relying on speedfan (as I was) I thought my temps were fine, try using intel TAT or everest ultimateotherwise thats a nice OC on air
Tommysdad
Thats a good OC on air then, there`s that many different programs and readings it gets a bit confusing.I check with TAT but installed coretemp yesterday
Tommysdad
, but I'm very happy with it. Must have been a lucky day - of course if it all melts I'll post and vent my fury at CoreTemp
36 c with Q6600 @3.3" Noctua u12f" fan on low
Idle or stressed? (the CPU that is!)
About 32 idle ,36 gaming 40 during max out stress testing and thats on low fan setting !
