Hey everyone,
Just got a Q6600 to replace a AMD64 3500+. I've coupled it with a Thermalright Ultra-120 Extreme and Scythe 1600 120mm fan but I'm just wondering about the temp readings I'm getting.
In Core Temp I'm getting 26-27 for two of the cores and 33-35 for the other two, but under load (Prime 95 torture test) the difference between the two sets of cores rises to around 12 degrees (42-44 and 52-55).
Just wondering if I should be slightly worried about the large difference in temps? Should I have a go at reseating the heatsink?
Cheers
Cheers
