There you go then, your mb has set the vcore correctly.
Worth noting you have a decent Q6600 also, generally the lower the VID the higher it will clock, 1.2750 is average.
75c max! try and keep under 70c if possible and only trust core temps reading.
You shouldn’t be running anywhere near that with stock vcore and clock even with the stock cooler on full load, but yeah if you want to know what to keep under when you overclock, around 60 under full load is nice and safe.
yup, 5-6c difference is normal, your temps look fine for air.
What cooler are you using?
yeah, the fins get very close towards the centre of the cooler where they meet at the heat pipe. I used the same cooler on my old amd opteron dual core chip for a while and it was forever gathering dust!
As your cpu runs a low vcore I would assume it is a G0 stepping, I think that cooler may let you overclock with stock volts and no more.
Do you intend to overclock the cpu?
no dude, it’s the chipset! the Intel 965 starts to give up at around 380fsb with quads. your doing well!!
You more than likely have an awesome chip there but your board will limit your overclock tremendously!
My E6600 was happy as Larry on my old Asus 650i motherboard running at 3.8Ghz, I tried my Q6600 on the same board and I get stuck at 3Ghz!
I'm now using a P5K premium P35 board and I'm rocking along at 4Ghz with the same Quad! thats how much an mb can limit you.
You will find your cooler will limit you soon as temps start to climb.
A new motherboard won't help the temps no, that HSF will struggle with a Q6600 as the voltage increases. But Hesky82 is correct the 965 may well have problems at 400 fsb with a quad and the boards power regulation is having to supply a lot more current. It will limit the overclock.I don't see how a mobo change will drop my temps to be honest as i've only increased the voltages from 1.225 to 1.260, the fsb issue is pretty minor but itself is not limiting the overclock of the CPU.
