Hi all, this is my 1st post and i have done a search to see if there is a thread already running on this, can't find anything but apologies in advance just in case.
Right, i have Q6600 running at 3.01mhz and all 4 core temps are different, this i know is usual but...the difference is, i think too big to be normal.
Core 0 = 31
Core 1 = 33
core 2 = 37
Core 3 = 39
Core 3 is always 9-10 degrees hotter than 0 with the middle two somewhere between.
These are my idle temps, core 3 gets upto 71 under load while the others stay below 60. I have a Arctic Freezer Pro 7 fitted and have reduced the volts slightly to 1.35. Everything is stable, no hiccups, so should i take any action about the differences, or just "shut up and play"?
Core 0 = 31
Core 1 = 33
core 2 = 37
Core 3 = 39
