Q6600 fail overclock?
11 Feb 2007
I overclocked my q6600 to 3GHz last week and ever since I did it when I turn the computer on, it comes on for 1/2 a second then goes off. I then have to wait a few seconds to turn it back on, it always does this.
The overclock is 333 x9.0
What have I done wrong?
Thank you.
It didn't do it before the overclock which is what I find wierd. I have also just run Intel Burn test (did 5 runs) and it completed it with the result as stable.
It's normal as other people say. Just reset the BIOS and start again. Are you sure you are disabling all the correct things?
