- 10 Dec 2007
Just put together a Gigabyte P35-DS3P, Q6600 and 4GB OCZ DDR2 800MHz. Trying some fairly tame overclocks at the moment, and I don't seem to be able to get even a mild OC to remain stable. At 2.8GHz (400x7) with 1.4V vcore, the system falls over and dies within a few seconds of starting a Prime95 'In-place Large FFTs' or 'Blend' test. The RAM is unlinked and set to 2.0x, which should be OK, right? (I am relatively new to overclocking so apologies if I have neglected to mention something obvious)
After doing some searching for posts by other people who've had stability issues at such relatively low speeds, and reading this thread, I tried running a Prime95 'Small FFTs' test and that appears to be perfectly stable. What does this indicate?
Thanks in advance,
mg
Thanks in advance,
mg
