Hey Guys,
Right i'm on my first ever overclock and would like a bit of advice from someone. I'm running the following setup....
Q6600
Artic Freezer 7
Artic 5 Thermal Paste
ASUS P5Q Pro
OCZ 8500 Gold ram 1066 4 x 2 ( 8 Gig )
NVIDIA 8800 GTS ( 320 Meg )
Antec 902
I've just overclocked to...
CPU : 3.3 ( 367Mhz x 9 ) AUTO
RAM : 1106 ( 5-6-6-18 ) MANUAL
Confusion starts here......
VCore is showing as 1.44V ( Speed Fan )
VCore is showing as 1.44V ( CPUZ )
VCore is showing as 1.325V ( Core Temp )
Speed Step : Disable
Max CPUID : Disabled
CPU TM-Function : Enabled ( am I right this stops it blowing up ? )
Execute Disable Bit : Enabled
PCIE : Set to 100 ( Not going over in case of damage to GFX card )
I've also left NB on Auto as didn't really wanna mess with it but I read 1.4 is a giid voltage to set it at on this mobo but unsure if its a good idea.
This is running on Vista 64 bit OS and case fans are turned on medium as don't want it to sounds like a alien spaceship as it already looks like one
*I have just ran Prime95 for over an Hour and the CPU temps are reading at*
67
67
62
61
I'm quite happy with this as did not want to go over 70 althought I would like it if it were cooler. I feel the VCore is a bit much too. I'm now thinking of lowering the voltage to see if I can make it got a bit cooler.
I was wondering where would be a good place to start. I was thinking of lowering the VCore a little bit at a time then running Prim95 for 30 mins. Any suggestions on what to VCore to start with and how much I should take it down each time ? Also unsure if SpeedFan is a good program to check VCore with as CoreTemps shows it as 1.3250V, Where should I start ?
Sorry for the big post. Hope I've covered everything in it and would really appreciate some help.
Thanks
Kev
Q6600
Artic Freezer 7
ASUS P5Q Pro
Antec 902
67
67
62
61
Thanks
Kev
