Q6600 G0 SLACR on XP - which temp monitor to use?
Ste
Ste
18 Oct 2002
Hi all,
As title really. I've heard about having to add +15'c to temp readouts with many programs, are there any that are accurate with no messing about? What do people recommend using?
Thanks
With two instances of orthos (100% cpu) I'm reading at 33'c load on two cores and 40'c one the other two? Stock everything.
Bearing in mind this is on air (thermaltake ultra extreme with push/pull) this is a bit low isn't it? Is it more likely to be +15'c?
TAT reads the real core temps, and there's no need to add 15 oC onto what TAT reports. Even on a G0 stepping. They do seem very low temps, so I guess you ain't overclocked it yet.
Get prime95 (P95V253) this will save you opening two orthos.
no on-die temperature reading will be truly accurate, but they are a good estimation.
they're not accurate because they've not been calibrated.
There seem to be three programs that I have tested that give accurate temps, TAT, Coretemp and Everest
