Q6600 G0 temp ok ?
Thats a very low load temp, what application are you using to test load temps? It seems to be recommended that you dont put more that 1.5v through these CPU's, is that BIOS voltage or what you get in CPU-Z?
Have you run prime to check if its stable? Whats the voltage in CPU-Z? Mine idles between 30-33 depending on ambient (its been pretty cold lately and ive always got the windows open), BIOS voltage is 1.4525v in CPU-Z its actually 1.37v. So your temps seem about right if the vDrop is around the same.
