Hey all, after sticking with my horrific stock heatsink for ages I've decided that the noise it's putting out has to go and I'm going to upgrade to a better cooling solution.
My only concern is that I've got a Lian Li PC-A05 and that a gigantic heatsink might not fit properly (I'm probably wrong) so I just wanted to get your advice and recommendations on what to get? Money isn't really an issue, although I don't want to go silly.
Cheers!
Cheers!
any of the above are way better than mine
