Hi guys,
I've been running my Q6600 at 3ghz since I bought it a while ago. I'm trying to up the clock speed to 3.2ghz which I've seemingly done so far, it runs without issues and seems stable. My only issue is that in the bios the ram is running at like 1068 instead of 1066. I'm guessing the reason I can't get it to match is because of the DRAM:FSB ratio?
I'm using the asus P5KC and there doesn't seem to be an option to change the ratio, unless it's called something completely different, I've even searched the manual.
I just don't like the idea of the ram running at over rated speeds, even though the motherboard shouldn't support past 1066 afaik.
Any help is apreciated,
Cheers
Cheers
