Okay this machine is not new and I've been thinking to go i7 but first I thought I'd over clock see if I could squeeze it up a bit.
I got the thing up to 3ghz fairly easily which left my memory running exactly at stock but then had stuff to do so I thought I'd leave getting the next Ghz out of it till later. I booted it and started using it and from one point of view it run rock solid however it seemed to have gained a slight stutter. operations like moving the mourne seemed to have gained the tinniest delay but added up the experience became frustrating. Any way last night I asked my wife if she'd noticed the PC doing anything strange. she described the same stuttering so I reduced to stock and all was fine.
Memory running at 667 (which is Spd although rating is higher OCZ2N1066SR2GK)
cpu is a GO stepping Q6600 at 333 x 9 (temps 50 ish to 42 ish across the cores)
PCI-e fixed to 100
Motherboard is a Gigabyte P965-D3 (rev 3) from memory.
I have a thermaltake NB cooler with zip locked small fan and an Zalman 9500
I've only just started the easy bit and fallen at The first hurdle, what am I doing Wrong.
PCI-e fixed to 100
