Q6600, is there an easy way to check its G0?
27 Aug 2004
Geordieland
Bought the CPu as it was on offer in a different store, so dont have the rest of the system, only i expected the box to have G0 stamped all over it or similar, and it doesnt, is there any way i can tell whether its G0 or not just by the codes on *** CPU or something?
Cheers
On the side of the box there's a big label, if you look at the Product Code, if it ends in SLACR it's a G0, this should also appear on the CPU as well.
Jokester
Bingo, it is the G0 then, thanks for that, i was beginning to get a nervous twitch they had sent the wrong one. Now just need the GFX card and RAM from OcUK on Monday and then i have a wait until the 17th for my Shuttle :(
