27 Mar 2008 at 21:31 #1 Dob1eman Dob1eman Associate Joined 24 Apr 2007 Posts 168 Location Derbyshire In Speedfan I added the +15 to each core because it's Quad and my Core 0,1,2,3 are all fine temp wise. However the one saying temp just below Core 3 is at 60c and can reach 72c is this a problem?
27 Mar 2008 at 21:52 #2 Rackerz Rackerz Associate Joined 6 Apr 2007 Posts 1,570 Location Portsmouth Have you tried using coretemp just to confirm temps?
27 Mar 2008 at 21:59 #3 Dob1eman Dob1eman Associate OP Joined 24 Apr 2007 Posts 168 Location Derbyshire In Coretemp the temps are OK they are low to mid 40s just checking that the temp reading in Speedfan is not a problem?
28 Mar 2008 at 13:39 #4 Dob1eman Dob1eman Associate OP Joined 24 Apr 2007 Posts 168 Location Derbyshire Any Advice?
28 Mar 2008 at 17:43 #5 knockonwood knockonwood Associate Joined 23 Dec 2007 Posts 63 Location online the temps in speedfan r by far not accurate .... i did a similiar thread the other day mate was advised to use core temp or 0cct my temos at stock speed are around 25 on all four cores. Last edited: 28 Mar 2008
28 Mar 2008 at 17:55 #6 Dob1eman Dob1eman Associate OP Joined 24 Apr 2007 Posts 168 Location Derbyshire knockonwood said: the temps in speedfan r by far not accurate .... i did a similiar thread the other day mate was advised to use core temp or 0cct my temos at stock speed are around 25 on all four cores. Click to expand... Many thanks just wanted some advice on the matter, I thought speedfan was wrong but always best to check. I will stick with core temp from now on.
