Hi guys,
I'm currently running the spec in my sig. Just trying to get 3.2 Ghz at 400x8, but I getting errors in prime95. My vcore is currently at 1.375, which I believe is enough.
I think the problem is to do with my memory multiplier. I am unsure what I should set it to in my BIOS as the settings confuse me a bit. You can either choose selection A,B,C or D with varying values from 2.0 up to about 4.0. IIRC it says that B corresponds to 333Mhz FSB, D 400Mhz and I can't remember A and C. Will check if necessary.
Here are my screenies from CPU-Z:
Does anything look out of the ordinary here? I believe that I should be able to get to 3.2Ghz with my cooler quite easily, but seem to be struggling?
Cheers, Rob
Cheers, Rob
