My Q6600 is running at 360MHz x 9 multiplier with 4Gb memory running at 467MHz
This gives a nice gentle clock of 3.2 GHz on 1.31volts.
I have been running an encoding/decoding benchmark for the morning (about 3 hours)
My temps are holding steady at 36 degrees C in a 19 degrees C room. The load over each core is holding at about 80-85% load.
The fan on my Zalman CPU cooler is spinning up at 1500-1700rpm self regulated!
I'm pretty impressed with these temps, speeds under a good load.
(I use this type of load as it is what is likely in gaming, general hard use)
What does the board think. About right?
Ta
Andy
Ta
Andy
