just installed a q6600 i bought from mm
it has a Vid of 1.3
ive got it to 3.6 ghz with 1.472v going through it acording to cpu-z
ive had it stable under prime95 for 45 mins now but the temps are reading 74 67 67 75 on core temp
now this is a little high for my water set up dont you think ? (thermochill 120.2, ddc, apogee gtx)
i'd put the two reading over 70 down to the fact i'm using the larger o ring in my apooge gtx
so my question is, will the 74 odd degrees c hurt it and is this high for water ?
i fancy an EK supreem as ive heard good things about them
cheers
it has a Vid of 1.3
cheers
