In a last ditch attempt to wring a little extra performance from my archaic P45 / E8600 /GTX280 rig I decided I'd try a Q6600 (picked up cheap second hand).
Now currently my E8600 is air cooled and overclocked to 3.8 GHz using the stock intel cooler it came with.
My intention is to OC the Q6600 to around 3.2GHz - am i likely to need to replace the cooler to achieve this or will the stock intel cooler that came with my E8600 suffice?
Many thanks
Many thanks
