Q6600 OC'ing without data corruption?
1 Dec 2004
Glasgow, Scotland
Hi guys,
Got what is probably a very simple overclocking question.
Ive been running my Q6600 G0 at 3GHz on its stock cooler since I got my new PC. Running coretemp and prime95 didnt show up any issues so thats been ok since November.
However I recently installed a new hard drive and was copying 100gb of HDV AVI files for video editing and decided to do a file compare afterwards to make sure my drive was ok. To cut a long story short there were errors as the files didnt match and after trying this and trying that it looks like its down to the system being overclocked.
When copying data the CPU isnt being taxed at all so I dont think its overclocking the chip thats the problem, more the motherboard or system bus but thats where my knowledge ends as the last time I OC'd something it was a Celeron 300A and it was a very simple job.
Im running a Gigabyte P35-DS3R motherboard, latest F11 BIOS and GEiL DDR2 value memory (BIOS reports 800MHz for it).
What things should I try first to keep my system OC'd but running stable.
As I said, the PC seems fine, been playing CSS, Crysis, doing video editing in Sony Vegas with no apparent problems, but obviously something is amiss if file copy ok when standard but I get CRC/MD5 differences when copying OC'd
Thanks for you help folks,
R.
Data coruption is usually a memory or hard drive problem. Are you running your memory at 2.1v?
Hi Cob,
The hard drive is fine coz when I run it not overclocked it transfers data fine. I'm not sure how the memory is setup, I just left it on the defaults as suggested by the BIOS's inteligent tweaker (MIT).
Im not at home right now so cant check it. DOes increasing to 2.1 usually sort this kind of problem out?
Many thanks,
R
Actually the value Geil may be ok at the default 1.8v, but try it at 1.9v. If that doesn't help then up your vcore by a notch.
Here;s the dump from CPUZ when running at stock settings, just in case theres something in there that doesnt look right.
CPU-Z version 1.44.1
Processors Information
Processor 1 (ID = 0)
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Package Socket 775 LGA (platform ID = 4h)
CPUID 6.F.B
Extended CPUID 6.F
Core Stepping G0
Technology 65 nm
Core Speed 1600.1 MHz (6.0 x 266.7 MHz)
Rated Bus speed 1066.7 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.0x
max VID 1.275 V
Features XD, VT
Chipset
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IR (ICH9R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual (Symmetric)
Memory Frequency 400.0 MHz (2:3)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 18
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) GEIL (7F7F7F1300000000)
Size 1024 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number CL5-5-5DDR2-800
Serial number 00000007
Manufacturing date Week 27/Year 07
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 400
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 18
TRC 12 16 23
DIMM #2
General
Memory type DDR2
Size 1024 MBytes
Serial number 00000003
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 18
TRC 12 16 23
DIMM #3
General
Memory type DDR2
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 18
TRC 12 16 23
DIMM #4
General
Memory type DDR2
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 18
TRC 12 16 23
Monitoring
Mainboard Model P35-DS3R (0x201 - 0xA445CA)
LPCIO
Vendor ITE
Model IT8718
Vendor ID 0x90
Chip ID 0x8718
Revision ID 0x4
Config Mode I/O address 0x2E
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0 1.12 Volts [0x46] (CPU VCORE)
Voltage sensor 1 1.89 Volts [0x76] (DDR)
Voltage sensor 2 3.34 Volts [0xD1] (+3.3V)
Voltage sensor 3 5.00 Volts [0xBA] (+5V)
Voltage sensor 7 12.16 Volts [0xBE] (+12V)
Voltage sensor 8 3.14 Volts [0xC4] (VBAT)
Temperature sensor 0 45°C (112°F) [0x2D] (TMPIN0)
Temperature sensor 1 30°C (85°F) [0x1E] (TMPIN1)
Fan sensor 0 1386 RPM [0x1E7] (FANIN0)
Hardware monitor
Intel Core 2 Quad Q6600 hardware monitor
Temperature sensor 0 35°C (94°F) [0x41] (core #0)
Temperature sensor 3 35°C (94°F) [0x41] (core #3)
Temperature sensor 2 35°C (94°F) [0x41] (core #2)
Temperature sensor 1 33°C (91°F) [0x43] (core #1)
