Q6600 - £173.89
E6850 - £176.24
Q6600 - 4 cores
E6850 - 2 cores
Q6600 - 2.4Ghz Overclocked -3.4-3.6Ghz
E6850 - 3Ghz Overclocked - 3.6-3.8Ghz
Q6600 - WINS, 4 cores are better than 2, difference in performace by 200-300mhz in real world = nothing. Plus its cheaper.
Check out this aswell.
http://www.xbitlabs.com/articles/cpu/display/core2quad-q6600_8.html#sect0
Multithreaded games - Designed for multiple cores so why get a 2 cored CPU when future games will use more than 2 cores, especially when the quad core is cheaper.
Q6600:
Quad core, 2.44Ghz, 1066fsb, requires PC8500C5 memory which is a bit more expensive, still very fast, not many apps use quad core yet, but games like Crysis and UT3 will bennefit from it, also retails about £170.
Q6600:
Where do you get the idea that it requires PC8500C5 memory from?
I sent my mate the following spec and he told me:
"you would also need to change your memory for PC8500...
GeIL 2GB (2x1GB) PC8500C5 1066MHz Black Dragon DDR2 Dual Channel Kit (GB22GB8500C5DC) for £99.99!!!!"
I'm no big builder of systems so took what he told me as right. I take it its not. Below is the spec I sent him to comment on and he recommended going for the e6850 rather than nthe Quad.
Gues I'll stick with my original and blow my wod on Quad!
