Q6600 or Q6600 ? brain scratcher
12 Jun 2007
Ireland
Hello i currently have q6600 the simple one and i am planing to buy some watercooling soon hope to oc to 3.6 ghz is there much point to buy G0 for me ? should i buy first watercooling and check how far i can overclock ?
The main advantage of the GO is less heat, but sonidering you want to go on water, your heat issues with your current Q6600 should get washed away and it should oc higher.
