Hi,
Looking to build a new PC in the next few weeks for around no more than £550.
At the moment, i'm running an X2 3800+ with 2gb DDR and an x1950 Pro 512mb.
The Q6600 has twice the cache, and is known to overclock well with the G0 variety. However, it is now discontinued and also 65nm process, which means extra heat output over 45nm. On the other hand, the Q8300 is a new product with lower power/heat output, and thus has a probable chance of overclocking well. However, it has half the L2 which is quite a significant drop?
Can't afford anything higher than these two really though.
Main uses will be for overclocking for music production and audio and video encoding, as well as gaming.
Thanks.
Thanks.
