Hi i would like to overclock my q6600 to 3.0Ghz here is pics of my max and idle temps with out the overclock useing a Samuri Revision B CPU cooler is the temps good to reach 3.0Ghz? Also i was told that the max CPU temp for the q6600 is 62.2c and also here is a link isit true?
http://www.hardwaresecrets.com/article/143/5
Thanks for your help.
Max-Temp
http://www.freeimagehosting.net/imag...0a43d4e59a.jpg
Idle-Temp
http://www.freeimagehosting.net/imag...1688b772d6.jpg
Max-Temp
Idle-Temp
