- 11 Sep 2008
- Northern Ireland
Am thinking of overclocking my Q6600 but I only have the stock fan. How much could I safely overclock it? Or do I need a CPU fan before even thinking of doing it?
It depends.
The VID of your chip, your motherboard your ram etc.
Intel Core 2 QuadPro Q6600 8MB
Corsair 4GB DHX XMS2 (2x2GB)
Asus P5Q Deluxe Intel P45
Cooler Master Cavalier 3 T03 A
Sapphire ATI HD4870 X2 2048MB
1000W power supply
VID?
1000 watts? Bloody hell what you building a 747?
Well why would you not want a fan on the heatsink?
1000w and no watercooling?
shame on you
i suggest starting out for a 3GHz overclock on stock volts - even the newer [lesser] q6600s should be easily doable
set your multiplier to 9 and the fsb to 333
gives you 3000mhz
or 3GHz
then check your temps
i would upgrade to a good quad aircooler if you want to push for more
then you can look at upping voltages and going higher - realistically - unles you get a miraculous low VID chip then you should be only looking at 3GHz on stock cooling
a TRUE is on this week only and it looks very swish! - worth the investment imo
you will need a 120 fan to go with it as well
