Trying to overclock my Q6600 to 3.6GHz on a P5Q deluxe, which I can boot into no problem. And even play Batman AA. However when it comes to running Prime 95 it falls flat on its face after about a minute.
I had everything on Auto in the bios previously but then I manually set most of the voltages etc And most notably Core Voltage is at 1.43 odd @ 450 * 8 = 3.6GHz
Problem is that Coretemp is reporting very high temperatures (into the 90s). And this is obviously a no no. And in fairness P95 does fail after about 10 mins.
Hex mentioned that I could drop the core voltage and play around with the FSB, PLL and NB voltages to compensate, but I have had no luck.
Now I dropped my FSB to 440 * 8 = 3.52GHz and P95 runs no problem.
But I still have this temperature issue.
Now... short of adding extra fans etc (I have a red scorpion with the fan from the scythe ninja on the scorpion) + 2 case fans in a P180 antec case both set to low, is it realistic to be able to get Vcore of around 1.40 and still be able to run at 3.6GHz or is this just a pipe dream?
And as a last alternative, are there any high performance fans which are silent? For example I like the Antec Case fans (Tricool I think they are). Is there anything similar to those but with a higher CFM? Would putting two fans on the sink benefit?
Cheers.
Cheers.
