Bit of a wall of text incoming, sorry.
I got a q6600 to add a bit of umpf to my aging e6600 setup and have been having a few problems with the oc which I'm sure are related to my Asus p5b deluxe mobo.
I initially tried to run it at an identical oc to my e660 of 3.2ghz (400 x 8, 4-4-4-12 timings, 1.4375 vcore, all other voltages on auto) which was rock solid in prime 95 never going above 53 and idling at around 20 under normal desktop usage. There was a major problem though: the pci-e link width was locked at 1 at all times. I used to have this issue with my e6600 if I tried to restart and the way to avoid this was to wait a few minutes before turning the pc back on. For some reason using these settings on the q6600 results in my graphics card never switching to 16 mode.
I've tried numerous fixes: various tweaks to the pci frequency, disabling bios settings, updating the bios, changing the fsb to 401 rather than 400 and the usual waiting several minutes for a cold boot but nothing I could do would enable the optimal link width. A bit of a shame as the system was 100% rock solid in prime at these settings.
At this point I decided to go with a slightly lower fsb and a higher multiplier (9 x 380, ~3.4Ghz, 1.45 vcore, 4-4-4-12 timings, all other voltages on auto) et voila 16 link width at all times! Only drawback was that the pc was horribly unstable and would randomly blue screen not long after posting. I assumed this was the memory so set the memory voltage to 2.2 and the nb voltage to 1.4 and I was able to play Rift with no issues and also run 3dm without a hiccup. No dice in prime though as within a few mins the pc rebooted.
If it is the memory I don't get it as it's effectively running at 720 rather than the usual 800 at the new overclock I'm trying. Are there any further tweaks anyone could suggest please?
