20 Apr 2007 at 11:00 #1 drak3 drak3 Associate Joined 26 Jan 2006 Posts 1,502 Any ideas how these clock? Any attempts so far? Price is VERY ok and if it clock well is a no brainer me thinks.
20 Apr 2007 at 12:29 #2 RaiderX RaiderX Soldato Joined 18 Feb 2007 Posts 3,159 Location Wirral should clock about the same as an E6600, would just need better cooling for twice as many cores
20 Apr 2007 at 18:23 #3 IceShock IceShock Soldato Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire RaiderX said: should clock about the same as an E6600, would just need better cooling for twice as many cores Click to expand... incorrect, there two different cores all together. the E6600 is a conroe and the Q6600 is a kentsfield. not sure how well they overclock tho tbh
20 Apr 2007 at 18:25 #4 Jokester Jokester Don Joined 7 Aug 2003 Posts 45,023 Location Aberdeenshire Kentsfield is effectively two Conroe cores glued together and will generally clock much the same if you can deal with the heat. Jokester
20 Apr 2007 at 19:41 #5 easyrider easyrider Caporegime Joined 24 Dec 2005 Posts 40,250 Location Autonomy yup, My Qx6700 ran happily @ 3.6ghz under water although a tad toasty IIRC Jokester you ran orthos for a few hrs and temps crept up to 70c and you didn't kill it.
