Q6600 Ratios and Timings
23 Aug 2010
Hi there!
Feel to free to shout at me for being stupid or not understanding other topics about this properly but I'm getting thoroughly frustrated about conflicting information regarding 1:1 ratios. I have:
Asus P5Q Deluxe MB
Overclocked Q6600 G0 3Ghz (9x333)
Underclocked 2GB Kingston HyperX 1066 RAM (667)
Artic 7 Cooler
Basically I believe that the system is currently running at 1:1 but obviously my RAM is now running at around 50% of its maximum capable speed. Now if 1:1 really is all that important to performance can I not lower the CPU multiplier and up the FSB frequency in order to boost up the RAM speed - or is that going to effect something else performance wise. Everyone seems to go for a higher multiplier and lower FSB so I just assumed going the other way for the sake of faster RAM was a bad idea?
Conversely if I kept the RAM underclocked does this mean I might tighten the timings from 5-5-5-15 to something better (only just started looking into this so have no idea what is available just yet).
Also on another note I am running around 39~ on CoreTemp when idle and between 69-73~ under load. Is that within acceptable limits or should I have a look at my cooling again??
Cheers for any help you guys might be able to give!
I got visitors right now and work just after that but I will answer later (8pm), been playing with my P5Q deluxe and Q6600 for a good few weeks now.
Bunch of setting templates to share
Mine runs at 3ghz, 9 x 333, and I have the FSB strap at 333Mhz which allows me to select the 1066 dram frequency. First I've heard that running 1:1 was so important.
I am running 400x9 here. I can run 3.2Ghz, 3.4Ghz and 3.6Ghz all stable but I only ever choose 3.2 or 3.6 because 3.4 doesnt allow me to run 1:1 without unclocking the RAM.
That would be great. I fiddled around quite a bit when I got the board a couple of months ago and got it running stable but now I have the itch to push it a bit further! :D
How much did you have to tweak the voltage to get 3.2-3.6?
And out of interest how hot does it run and what cooler do you have running?
