Q6600 Refuses to OC
20 Oct 2002
North West
Right...
A few months ago my Q6600 ran at 3.2ghz happily (prime stable).
I then ran the Intel Linnpack test which proved it to be unstable.
I then ran at 2.8ghz stable.
Just after New Year I added an XFX Revo64 SATA card. Since then I have been unable to overclock at ALL.
If I set it to anything above 2.4 is resets to 1.87ghz.
Removing/moving the card is not an option. I'll hold off getting a new motherboard and go straight to an i7 when I can afford it.
However if I can get my chip back to 2.8 I will be happy!
I have tried:
  • New bios
  • Resetting the bios
  • Different multipliers
  • Auto voltages/tweaked voltages
It's a real PITA!
My motherboard automatically locks the PCI speed to 33mhz.
Thanks anyway.
Just managed to get it to boot with 400*7/+0.3MCH voltage but if I restart or shutdown it resets to 1.87 for some reason.
If it's the mobo listed in your sig then have you tried upping the NB volts, I had an old P965 DS3P which used to do this and upping the NB helped.
