Q6600 Retail Thermal Grease
5 Jul 2004
London
Hi all,
Quick question. Just purchased a retail Q6600 and have inserted into my motherboard and placed on the heatsink/fan (following the instructions provided) and realised nowhere does it mention applying any thermal grease... which is handy as I don't have any.
Is this normal? Are you supposed to put some on or can the Q6600 do without? I won't be overclocking at all.
Thanks.
You at least need the thermal pad from the stock Intel heatsink if your not using the stock intel heatsink then yes you have to have some thermal grease.
