i get 62c at 3ghz with my q6600 g0 stepping
corev 1.47.....
Tuniq Tower 120-LFB CPU Cooler
help
Thats a lot of vcore for a 3ghz clock... do you really need that much... I would imagine that 1.35v load vcore should be enough
corev 1.47.....
help
My CPU temperature was just over 74c The Asus AI probe software gave me the warning?? I'm using the original stock cooler all fans are working in bios everything is at "defaults"
Cool, thanks for that.. and yes, I have a DFI BIP35-T2R "Blood Iron" - any way to cool down the chipset further, seems a little hot right now?The Arctic Freezer Pro is pretty cheap and quiet.
I think Smart Guardian displays the same temps as the bios (you got a DFI mobo?).
install coretemp and prime95, run a small ffts test and take the coretemp readings
Those are way to high, what speed is your cpu at, and what cooler are you using.Hiya sorry back to this have been busy didn't get time to test - But now i have installed Coretemp and prime95 and run a small ffts test as above:
Seems to me to be your cooling isn't working - just to state the bleeding obvious! Have you re-seated the CPU cooler? How is the cooler being controlled? Auto in BIOS? Are there thresholds that need to be set in BIOS?
I had this problem when I first got mine too... I didn't realise that less was more with the thermal paste. Took it all off, reapplied the thermal paste and the temps are acceptable now![]()
Yes have tried re-seating the cpu cooler its on and running at 2109rpm? In bios its all at Fail safe defaults at the moment!
