Hey Folks..
Just placed my q6600 under water and was greeted with a scary moment on loading TAT. After loading up prime95 x4 to max out the processor, the temp went into the red and now says on screen... >100 (in red).
Obviously, a bit of panic kicked in but i checked my loop was in order and everything is fine. Now, its get a bit wierd because prime has now been working for the last 20mins and on touching the water tubes, they are in fact cold (or luke warm at most).
I cant feel any great heat coming from the CPU block even though admittedly i cant actually physically reach it, but at 100c i'm sure you'd get a warmth.
Also, I have taken off both side panels and on placing my hand on the rear side of the mother board holding panel thing (Antec p180) there is no obvious warmth where the CPU is. There is warmth on the rear of the north bridge cooler.
Did notice when I first loaded tat, it said -27c.. nice, but not likely
So, is there some sort of cold bug with TAT. Its my first venture into the world of intel so i'm a bit lost.
Oh yeah, everything is at stock. Not changed a thing in the bios
Help me!!!! Still feeling mighty nervous seeing a big red >100c sign!!
Cheers
Cheers
