- 9 Dec 2007
I'm currently running a Q6600 processor with an IP35-E motherboard, and something appears to be wrong.
I am registering temperatures around 80oc idle and 90 under very light load, at which point the computer is set to shutdown - Which gets annoying, as I'm sure you will understand.
I'm aware fitting an after market cooler will some what help, if nt solve, this issue and I fully intend on getting one. However, is there something else wrong as well? Do Quad's normally run this high?
